Tire Wear
Old Feb 17, 2014 | 07:14 PM
AaronJG's Avatar
Default Tire Wear
Iv taken my truck in to get the front end checked(bearing alinement etc) and i noticed it feels odd in the steering so i checked the front tires. The drivers side has nice even wear and the passenger side is very worn-en on the out side and hardly worn-en on the inside. Took it back and they said all was fine when they looked at it. I have a feeling there full of it so i figured u guys would prob be better than going there again
Old Feb 17, 2014 | 08:06 PM
blackbirdls1's Avatar
Prob your outer tie rod, I had this issue.
Old Feb 17, 2014 | 09:03 PM
AaronJG's Avatar
ya i was thinking it was some thing up there not right i took off the old tire and but on my spare for a few days (away at school so kinda broke as hell) and i did the grab the tire and push pull to check the wheel bearing it didnt budge at all
Thanks, Aaron
Old Feb 17, 2014 | 09:49 PM
you can visually see if a tie rod is worn usually it will be ripped or cracking at the bushing/rubber boot if that's the case its like 12 bucks or something on rock auto easy fix
Old Feb 18, 2014 | 02:07 PM
rudytirerack's Avatar
LS1Tech Platinum Sponsor
Suspension issue and/or alignment out of whack.
Old Feb 20, 2014 | 10:11 PM
AaronJG's Avatar
good news just needed an alinement
Old Feb 22, 2014 | 09:00 AM
AaronJG's Avatar
my alinement was so out that it took em 3hrs to get it just right and found out my shocks are shot and my front right axle seal is leaking. Not nearly as bad as i was thinking lol
