What should i need to mount GM TPMS on my wheels?
Old Mar 20, 2014 | 07:01 AM
Revived's Avatar
Default What should i need to mount GM TPMS on my wheels?
I ordered GM TPMS Sensors.
There is already a 90 stem the enters the barrel of the wheel on the flat part and there is also I bolt driven through the Dipped area on a angle with 2 nuts on the end.
I need some help trying to find out how to mount TPMS on my configuration I was told I could use a big filter clamp around the whole wheel but I rather not do that or buy new adapters for like 100$ and I also rather not do that.
Any options for me here?
Old Mar 21, 2014 | 06:23 AM
leadfoot4's Avatar
Several years ago, one of the 3pc wheel makers made a fancy holder for a sensor, and it mechanically held the sensor down in the dropped part of the rim. I saw a picture, and it looked ingenious. I can't, however, remember if it was CCW or HRE. You might try their websites.
Old Mar 21, 2014 | 03:31 PM
Revived's Avatar
HRE is awesome gotta say he knew instantly what I was dealing with.
The consesis is the bolt in there now is simply a plug. All I need to do is remove it and then pop my tpms sensor in.
Thanks for the recommendation!
Old Mar 22, 2014 | 06:59 AM
leadfoot4's Avatar
Just be careful, though, that the tip of the sensor clears your brake caliper, as it will stick out of the wheel a bit...
