Any way to replace studs without taking axle off?
Old Apr 16, 2014 | 04:06 PM
countryguy1717's Avatar
Default Any way to replace studs without taking axle off?
My 98 Z has TCS, I need to replace the rear studs. I was told I'd need to pull the axle. I'm just wondering if there is a write up out there that shows how to do it? I saw one video where the guy hammered out the old studs, unplugged a sensor behind the brakes, and fished out the old ones and slid the new ones through then pressed them with an impact and a washer.
Old Apr 17, 2014 | 06:48 AM
nikon1999's Avatar
I've always done it the way you mentioned, remove ABS sensor and hammer it out threw that hole. Use a washer and old lug nut to pull it threw
Old Apr 17, 2014 | 08:15 PM
Is it pretty easy? I just don't wanna get stuck with a stud jammed in there...
Old Apr 17, 2014 | 08:16 PM
99FBODY's Avatar
That's the way I've changed all of my rear studs
Old Apr 18, 2014 | 07:59 AM
nikon1999's Avatar
Countryguy -
Takes maybe a half hour. If you take your time. Very easy
