Nitto Drag Radials On Road Course
Old May 17, 2004 | 11:29 AM
ChitownLS1's Avatar
Question Nitto Drag Radials On Road Course
How will Nitto drags handle on a road course? Any recommendations on tire pressure?
Old May 17, 2004 | 11:32 AM
gator's 99TA's Avatar
if you want to be competitive, i wouldnt suggest it at all,. the sidewall is far to weak for the lateral pressures in cornering. but if you still do, go as high as possible. over 40 psi - and yea tire wear will eat you up at that pressure.
Old May 17, 2004 | 11:38 AM
ChitownLS1's Avatar
It's not a competitive event. Will I be better off with the V-rated all season Falken Ziek tires I own? I have the Zieks on the front now.
Old May 17, 2004 | 12:36 PM
2_wacko's Avatar
Why don't you get the road race Nitto's.
Old May 17, 2004 | 12:38 PM
ChitownLS1's Avatar
I already own the drag radials.
Old May 17, 2004 | 01:09 PM
2_wacko's Avatar
There is a raod race tire not a drad radial check on there website www.nittotire.com
Old May 19, 2004 | 08:58 PM
98_1LE's Avatar
Be careful making assumptions, or taking them from those that have never tried.
Nitto drags are fine on a road course, especially the 17's. Several racers I have know have raced on them, and all of us liked them and were fast. I autocrossed on 16's DR's years ago and thought they were a little sluggish. I actually think my car is faster on a road course with Nitto DR's than with Kumho Victoracers in the same size. I run 315/35/17's on 17x11's at all four corners. They last a lot longer than Victoracers. The other thing I love about them on a road course is the fact that they make noise. It is much easier to drive them at the limit.
Photo 1
Photo 2
Video on drag radials
EDIT: I have also owned the 555RII, their road race tire. Actually I still do, and am on my third set of four. They are my street tires, also a nice tire, and basically only offered in a 275/40/17 (and very expensive 18's). They are a great tire, but not very different at all from the 555R.
Old May 19, 2004 | 09:37 PM
ChitownLS1's Avatar
Photo 1
Photo 2
Thanks for the great info!!!
Nice video.
Old May 19, 2004 | 09:45 PM
98_1LE's Avatar
Beautiful car BTW. I love silver!
One last thing. I would not suggest running stickies out back and street tires up front on a road course. Our cars tend to push (understeer) stock, and mismatching tires can exagerate this effect. You probably know this, but get a good set of front pads (I like Carbotech Panthers) and good brake fluid (Motul 5.1 or Ford HD), and have the following alignment done before RR:
Camber: max negative, or -2º (about -.5º is all you will probably get)
Caster: max positive, or +5º (lucky to get +4 stock)
Toe: 0. A little toe out will handle better on the track, but is a handful on the street. I run 1/8" toe out and love it.
Old May 20, 2004 | 08:34 AM
JoeDirt's Avatar
This is good info as the 555R's are mucho cheaper than the 555RII's :bow:
Old May 24, 2004 | 07:40 PM
69TA's Avatar
I agree with 98_1LE.....Nitto DR's kick *** as a road tire. I got them all around on my Firehawk and love these tires for handling. Don't worry about the sidewall....the only thing you have to worry about is treadlife as the tires are pretty soft.
