6 or 7 inch front tire
Old Jun 19, 2014 | 08:19 PM
slowdenali's Avatar
Default 6 or 7 inch front tire
what are you guys running for a front tire on a 6 or 7 inch wheel? I am running 18 inch wheel in the front and a 315 dr in the back.
Old Jun 20, 2014 | 10:01 PM
99Bluz28's Avatar
If you want to run a regular street tire then you'll need a 18 x 7 wheel to run a 215/45/18 which is 25.62", and it needs a 7" wide wheel minimum. FYI, this is the narrowest tire size I could find for a 18" wheel, but there's a good selection of tires available.
http://www.tirerack.com/tires/TireSe...45&diameter=18
http://www.discounttiredirect.com/di...Tires=0&cs=215
