longer wheel studs
Old Jul 7, 2014 | 02:45 PM
jmws615177's Avatar
Default longer wheel studs
I have a 1999 trans am and i am running deep dish c5 wheels ... i had to run a wheel spacer to fit the tires i am running and i was going to order longer wheel studs because only catching a few threads on stock studs but i heard you could pick up some hummer wheel studs and the parts store and they where the same as the studs on my car except longer. anyone know the exact part number or or what year model hummer this will work with?
Old Jul 7, 2014 | 05:39 PM
LS6427's Avatar
What thickness spacers are you using.....?
I ask because I might use a 1/2" spacer on the same wheels as you bought and Ill need longer studs too.
Im waiting to hear back from Motorsport Tech about it...they are making my 1/2" spacers.........if I hear I'll let you know what I find out.
Old Jul 7, 2014 | 07:24 PM
jmws615177's Avatar
I found out today and got mine in ... I'm running a 5/16 spacer and u can usee 2006 hummer (h3) front wheel studs they are the same as on our cars just longer ....if u want I can give the the part number.
Old Jul 8, 2014 | 11:15 AM
LS6427's Avatar
Can you tell us how long the factory studs are?
How long are those 2006 Hummer studs?
I guess it depends on the spacer used.....which longer studs you need to buy.
Old Jul 9, 2014 | 08:25 PM
jmws615177's Avatar
not sure the exact measurements till i make it back to the shop but i know the hummer studs are roughly a quarter inch longer. since you are thinking u will need a 1/2 spacer you will probably need to just order some going that big and id go with arp studs.
