Need help on ZR1 wheels
Old Jul 25, 2014 | 10:29 AM
mtl-biker's Avatar
Default Need help on ZR1 wheels
Need your help
I found at a good price a set of Forgestar cf 10 for sale it was on a Corvette C6 ZR1 offsets.
I saw on another forum a guy put original ZR1 on it with a spacer of 1/4
Front is 19x10
Back is 20x12
I want to put 285/40/19 on the front and 315/35/20 for the back with Michelin Pilot SS.
No tires was instal on the wheels.
When i jack up the car and try the 19/10 in the front it was very close of the shock i will need a 10mm spacer for more clearence and longer stud also
Did i need spacer for the back???
Thanks to answered
Mario
Old Jul 25, 2014 | 11:01 AM
dw456post's Avatar
It would be a good idea to tell us what kind of car you are putting these wheels on and the actual backspace measurements. If your car has fenders, it's a good idea to make sure the tires do not rub the fenders when you start using spacers.
Old Jul 25, 2014 | 11:02 AM
mtl-biker's Avatar
Sorry 2010 Camaro SS
Old Jul 25, 2014 | 09:30 PM
PantherZ's Avatar
I thought the 5th Gen Camaro had a slightly different bolt pattern then the C6
5th Gen Camaro are 5X120 mm or 5x4.72 and C6 are 5X120.65 mm or 5 X4.75
They will go on but if you look at the studs they are not centered up in the holes.
I don't know what kind of strain that's going to put on your lug bolts.
Old Jul 25, 2014 | 09:51 PM
mtl-biker's Avatar
Thanks i make my decision to pass on that sale, i will ordered brand new
Mario
Old Jul 29, 2014 | 10:03 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have run a set of replica 18x9.5 ZR1 wheels (40mm offset) on my 2010 Camaro SS all year. Rears fit no problem, just have to tie back e brake cable.
Fronts required mods, shaved part of the strut assembly and also ran a 5mm spacer.
I'm selling these local (Chicago) if anyone is interested, they also apparently will fit on 4th gen (though not the tires).
