backspacing ?
Old Aug 3, 2014 | 02:56 PM
purple turtle's Avatar
Default backspacing ?
Hey guys
I have a 1998 formula BMP going to put twosome ccw chrome classics on there. I have a few minor questions what's the biggest size tire on the rear I can use without rolling the fenders or fender rub? I would like to put a 275 on the front with a 315 on the rear. Any help will be great.
Old Aug 3, 2014 | 03:00 PM
Also time size will be a 17
Old Aug 3, 2014 | 10:16 PM
99Bluz28's Avatar
Up front with a 17"x 9" a +35 offset up to a +46 offset., or with a 17"x 9.5" a +38 up offset to a +46 offset. Then for the rear a 17" x 10.5" with a +44 offset up to a +50 offset.
Old Aug 4, 2014 | 06:53 AM
Thanks what about wheel rub will I need to roll the fenders?
Old Aug 4, 2014 | 09:52 AM
99Bluz28's Avatar
You might need a adjustable PHB to center the rear end from side-to-side as with any wide rear wheel/tire set-up, but you shouldn't need to roll the rear fender lips. if your car is lowered or soon to be lowered then I'd get a Adj. PHB and just to be on the safe side verify the rear tire to fender lip clearance.
Old Aug 4, 2014 | 10:24 AM
Car is lowered with adj PHB.
