Wheel width and offset?
Old Aug 28, 2014 | 01:45 PM
Jgodwin86's Avatar
Default Wheel width and offset?
I've got a 02 ws6 trans am what width wheel can I run on the rear? Also what size tire? Thanks for any help.
Old Aug 28, 2014 | 02:55 PM
HCI2000SS's Avatar
Depends....what diameter rim you want?
Old Aug 28, 2014 | 05:26 PM
99Bluz28's Avatar
So , are you looking for a plug-n-play fitment, or modified fitment..?
The widest wheel I'd run with no/to only minimal fitment issues is a 10.5" with a +44mm to +50mm offset. For tires you'll want a 295mm-315mm width.
Old Aug 28, 2014 | 08:43 PM
Jgodwin86's Avatar
Ive been looking at some weld rt-s 17s. I really don't want to modify anything to get them to work.
Old Aug 28, 2014 | 09:17 PM
99Bluz28's Avatar
This is what I'd go with, with a adjustable PHB to center the rear-end.
17" x 10.5", with a +44mm offset, use a 315/35/17 tire
17" x 9.5", with +39mm offset, or +44mm offset if you want it to sit about 3/16" more .
Old Aug 29, 2014 | 10:30 AM
Jgodwin86's Avatar
Ok thanks for the info. I found a pic I was going to post but I can't figure out how to do that.
Old Aug 29, 2014 | 02:36 PM
99Bluz28's Avatar
Well, for some reason the link to the photo shows up in my email alert, but not here when directly here on LS1tech. That's why I sent you the pm..
