Alignment and road crown?
The car doesn't drift on the road at all but my steering wheel is ever so slightly to the right when the car is going straight down the road but that has always been that way, so it's not from their alignment.
And to anyone whose had the alignment done to correct their tire wear, the shop said they had to slot the strut bolts as per instruction from GM... that is fine but has anyone had a reduction in performance when reducing the negative camber on their cars?
So you're probably right, some cars are just this way.
