Wheel question
Old Jan 27, 2015 | 04:33 PM
mcmuscle3's Avatar
Default Wheel question
Does anyone have a set of 80s model iroc z cAmaro rims? I Need to find what backspacing they are. Thanks
Old Jan 28, 2015 | 02:15 AM
99Bluz28's Avatar
For the factory 3rd gen IROC-Z Camaro 16 x 8 inch wheels the offset is 0mm up front and the rear wheels have 1/2" more back spacing so the rear 16 x 8's have right about +13mm offset.
0 mm offset = about 4.5" BS
+13mm offset = about 5" BS
I'd would just go with a 0mm offset/4.5" BS, F & R with the 16 x 8's .
So exactly what size wheels are you wanting to run, factor size..?
Last edited by 99Bluz28; Jan 28, 2015 at 02:28 AM. Reason: corrections, missing info..
Old Jan 28, 2015 | 12:22 PM
mcmuscle3's Avatar
Well I was told the iroc wheels are 4" back spacing. Thanks for replying and providing all that info btw... I have a 4th gen f body, ls1 firebird. A guy is helping me build a ford 9" to fit my car. I have one set of weld wheels 4 backspacing. I need another set of 4" backspacing wheels for the street also. That 9" is cut to fit 4" backspacing wheels.
Old Jan 28, 2015 | 12:23 PM
mcmuscle3's Avatar
Idc what size of wheel since it will be for the street. I just need something to throw on so I don't run my track tires out lol.
Old Jan 28, 2015 | 01:13 PM
99Bluz28's Avatar
American Racing (AR) does make a TT2 in a 16 x 8 and 17 x 8, both a available with a 4" BS(-12mm offset) on a 5 x 4.75" (5 x 120.6mm) bolt pattern.
http://www.summitracing.com/parts/are-5156861/overview/
http://www.summitracing.com/parts/are-5157861/overview/
So what size rear wheels and BS are your track wheels, and tire size..?
Old Jan 28, 2015 | 03:41 PM
mcmuscle3's Avatar
15x8 weld prostars with 4"bs, not sure the off set right now. Track tires are 28 10.50s.. Thanks for the links Im not a huge torque thrust fan personally. To be honest I'm just looking for something cheap I can throw on there to drive to the track
Old Jan 28, 2015 | 05:09 PM
99Bluz28's Avatar
The TT2's were actually the cheapest new aluminum 16" x 8", 4" BS wheels I found with the correct bolt pattern. I'm not the biggest fan of them either.
Old Jan 28, 2015 | 05:16 PM
mcmuscle3's Avatar
I appreciate the help, I was hoping I could find a dirt cheap set of stockers to toss and there and call it done. I'm not in a huge hurry, I think I remember seeing some on summit real cheap with 4" bs.
Old Jan 28, 2015 | 05:49 PM
99Bluz28's Avatar
Yeah, If you don't mind going with steel wheels you can definitely find cheaper wheels at Summit Racing.
Old Jan 28, 2015 | 07:27 PM
mcmuscle3's Avatar
Is there any negative to steel besides weight? Otherwise for street rims that would be fine for me
Old Jan 28, 2015 | 11:08 PM
99Bluz28's Avatar
None that I'm aware of. Even then I doubt the weight would be any issue in a 16 x 8 wheel.
