Need help switching center of centercap
Old Jul 25, 2015 | 04:46 PM
rxrom's Avatar
Default Need help switching center of centercap
I'm trying to make a center cap similar to the firehawk 10th aniversary. How do I get the slp center out of its housing. I tried using suction cup, tried using a micro screwdriver. What else can I try.
Attached Thumbnails Need help switching center of centercap-image-1770068391.jpg   Need help switching center of centercap-image-1132379785.jpg
Old Jul 25, 2015 | 06:48 PM
99'CajunFirehawk157's Avatar
I have to ask; why not just put it over the other emblem?
Old Jul 26, 2015 | 09:16 AM
rxrom's Avatar
The plastic is about 1/4" thick and will stick out instead of being flush. If all else fails that's what I will do.
Old Jan 13, 2016 | 09:13 PM
rxrom's Avatar
It's done. Put a screw in the middle making the plastic insert crack. Then edge of screwdriver to remove insert, then cleaned up the old glue and inserted the new center
Attached Thumbnails Need help switching center of centercap-image-2910668671.jpg
