tires for 15" wheels
Old Jun 9, 2004 | 12:57 AM
HotRod68Camaro's Avatar
Default tires for 15" wheels
Im goin to be running 15x8 and 15x6 wheels. What tires would work? DRs? It's for a 68 Camaro. I would like the rear to be 28" tall and 10.5" wide. It's a daily driver, that will see alot of street action.
Old Jun 9, 2004 | 08:37 AM
Derek98z's Avatar
what are you using them for? Daily Driver? Track? Both?
On a 15x8, I ran a 275/50/15 BFG radial for the street.
Old Jun 9, 2004 | 10:17 AM
sry will edit previous
Old Jun 9, 2004 | 06:29 PM
chevysol73's Avatar
hey clint checking in,i have had i ton of 68 and 67 camaros/27560r15 will fit no sweat,for the front depending on how much of the hot rod rake you like 1956015 or 21565r15 should fill your wheel well quite nicelly.if you run traction bars and have your rear shocks moved in mickey thompson 29x12.50 15 fit in there quite well too with the right of set rim which is what i have on my 68 right now on a 15x8 inch wheel guys run a spacer so they don't rub on the shock hope this helps see ya clint
Old Jun 25, 2004 | 02:43 PM
Hey clint you got any pics?
Kyle
