Weld RTS Help
The rear will be narrowed 3 in each side, I'm gonna run a 15x10 in rim,
What bs? 4.5 or 5.5, and also what pad height do I need to clear stock brakes?
I'LL be running a 275-60-15 if that makes a difference.
Thanks for your help!! If you have pics that would help also!!!
On the backspacing... Well that depends on the look you are going for.
If you want to put the wheel in the stock location you would need a 4.5 bs wheel with a 15x10. You take the stock bs of a 15x10 which is 7.5 and subtract the 3" that your narrowing to make it 4.5 for the stock location.
If you want the tucked look you would want to get the 5.5 bs wheel which would tuck it 1". Many folks have done it and it looks great. And if you don't like that much tuck you can run a small space to push it back out to your liking. Some say don't run spacers on the rear and other have also done it with no issues. That's up to you. Hope that helps you out.
On welds site, click on the rts parts, then on lugs. They have like 3 choices if I remember correctly. One of them being for 1/2 studs. That's what I have in the rear and what I did. The studs fits flush at the end of the open end lug.
