snapped a wheel stud. hard to fix?
Old Jun 13, 2004 | 09:52 AM
BigPlanTransAm's Avatar
Default snapped a wheel stud. hard to fix?
hi guys, my friend tells me to change a wheel stud you have to take apart the rear, remove the axle tubes, etc. My father says you just have to take off the caliper, and some little things. Who is right? is it really a big ordeal just to change 1 wheel stud or what? has anyone here had to do it before? and if so what all is involved in it?
Old Jun 13, 2004 | 10:44 AM
Black00Z's Avatar
If I remember correctly, just take off the caliper and rotor, and pound out the old stud with a punch and hammer. To get the new one in, use a bunch of washers between your lug and the rotor, and tighten the lug unit the stud slides into place.
Old Jun 13, 2004 | 10:51 AM
SLowETz's Avatar
Which rear? Not too tuff. If you got C clips you'll need to open the diff., and pull the C clip. If not you'll just remove the backing plate bolts and the axle will slip right out..... or.... you can cheat... and remove the caliper/disk/ABS sensor. Rotate axle until the stud lines up w/the "hole" in the dust cover. Knock the old stud out/insert the new stud. Press it in w/a socket wrench/washers.
Old Jun 13, 2004 | 10:55 AM
LS1Baron's Avatar
It usually takes two hits, out and in, with a dead blow hammer.
Old Jun 13, 2004 | 10:59 AM
cablebandit's Avatar
I just changed one on the rear of my tcs rear. I took out the abs sensor and that hole was perfect for the stud to go in/out WITHOUT removing the axle.
Old Jun 13, 2004 | 11:44 AM
onehardmaro's Avatar
Ive never had to remove the axle.
Old Jun 13, 2004 | 11:59 AM
Classic's Avatar
You do not have to remove the axle. Just remove the brakes, remove the ABS sensor, knock the stud out, and pull it back in with some washers and a lug.
