longer wheel studs needed
The spacers I bought, however, need longer threaded wheel studs.
What size studs should I use?
Where can these be purchased?
Can I install them by removing the brake caliper and rotor?
Here's how I installed mine:
https://ls1tech.com/forums/general-m...annel-abs.html
With the OE 2006 Z06 wheels, the flange where the lugnuts go is rather thick. Installing the factory lugnuts, the studs stick through about 1/2" in front and 1/4" to 3/8" in back.
