Wheel fitment questions
So I started by reading the sticky and this is throwing me off...
7.0" ............ +26 to +65 ........ 215, 225, 235
7.5" ............ +33 to +61 ........ 215, 225, 235, 245
8.0" ............ +39 to +55 ........ 225, 235, 245
8.5" ............ +45 to +48 ........ 235, 245, 255
REAR Only!
8.0" ............ +36 to +65 ........ 245, 255
8.5" ............ +42 to +65 ......... 245, 255
9.0" ............ +48 to +65 ........ 255, 265, 275
9.5" ............ +55 to +64 ........ 265, 275 (body mods are required)
The front, many say a 41mm offset is minimum to clear the Brembo's and then say that offset isnt a really good way to tell because its about the hub / spoke. I'm finding it fairly difficult to find a decent wheel with a 41mm offset. I'm almost prepared to accept that I may need a spacer but really trying to avoid that route as if I do, the whole job would have to be done by a shop as I have no way of changing wheel studs.
Can 19x10 be used in the rear without modification? What about the front?
Can 18x10.5 be used in the rear without modifcation?
Can 18x8.5 work in the front with a 41mm offset?'
Thanks.
