Weld prostars
Old Jul 24, 2016 | 03:34 PM
Chris25's Avatar
Default Weld prostars
I just picked up a set of weld prostars for dirt cheap 15x10 rear 15x 4 fronts. From what I have been reading I need longer wheel studs for the rear and I will have to grind the caliper to fit the wheel and the fronts will need longer studs with a 5/16" spacer? Is there anything else needed to run these wheels? Also how dangerous is it grinding the caliper I understand you have to get them pretty thin?
Old Jul 24, 2016 | 04:27 PM
Omega Doom's Avatar
not true I just recently bought some myself and mine were 15x10 with some grinding but not too much and then my fronts are 15x3.75 and a little more grinding but nothing scary now the important part is the tires for the fronts
Old Jul 24, 2016 | 07:50 PM
Chris25's Avatar
How so? They already have tires on the fronts.
