wheel adapters
Old Jun 20, 2004 | 03:41 AM
LS1CMR's Avatar
Default wheel adapters
does anybody know where i can get a wheel adapter that will bolt to my stock bolt pattern and has the pattern of a 5x41/2 bolt circle, i have a chance to get ttII for a good price but my friends f-body had a ford 9" rear end and that is why the two different circles, any help would be great, thanks chris m.
Old Jun 20, 2004 | 06:03 PM
slow's Avatar
you'd be better of getting custom axles made. unless his rearend is shortened 1-1.5" per side when you install the spacers your rears are going to stickout.
H & R makes adapters, but they're not cheap.
Ryan
Old Jun 20, 2004 | 07:25 PM
LS1CMR's Avatar
well the wheels ar made for a ford 9" so they are the ford offsetwhich is like 24mm, and the f-body no offset is like 55mmso an adapter wont make it stick out
Old Jun 20, 2004 | 07:33 PM
slow's Avatar
ok, so they're not just made for his bolt pattern, but for fords in general.
the H&R spacers should work great for you, they're about 30mm i think.
Ryan
