Need help I'd wheel
Old Dec 4, 2016 | 05:57 PM
billk1's Avatar
Default Need help I'd wheel
Does anyone recognize who makes this or what model rim it is, 16 x 9.5 x 5 x 4.75, 6.5 bs, supposedly fit ls1 rear brakes, guy said it was a weld but I can't find an id, looks to be forged 2 piece
Old Dec 6, 2016 | 09:50 PM
edzsilverss's Avatar
It's an old school weld draglite. Fit the rear with no grinding or issues. The front skinnies require a spacer and longer wheel studs. Also no grinding. See pic...
Old Dec 7, 2016 | 09:35 AM
MidwestChassis2's Avatar
Weld has always stamped their wheels. It appears to be a knock off wheel the way the center is.
Old Dec 7, 2016 | 10:40 AM
billk1's Avatar
I talked to Weld, they thought it might be an old draglite xp at first, but no Weld stamps and this rim has conical lug nut mounts which Weld only offered shank style, im looking at conical/shank lug nuts, holes look like they would take a .620 dia. short shank with a 60 degree nut, still don't know who makes the rim, 48 lbs -rim, tube, 275 MT bias tire , found a stamped number on the rear hub, 676507
Old Dec 7, 2016 | 01:42 PM
I blew up the picture it looks like they had a bolt on center cap. I kinda recall the company as they was based around street rod stuff in the 80's.
Added: it might of been Crager.
