Tire size and ABS
Old Jan 10, 2017 | 05:38 PM
ragtopz28's Avatar
Default Tire size and ABS
Will a 1.2% tire height difference affect the ABS?
275/40-17 front and 285/40-17 rear. Both Nitto 555..probably not just thought I'd ask..
Old Jan 10, 2017 | 05:41 PM
ragtopz28's Avatar
285/40-17
Difference
Diameter inches (mm)
25.66 (651.8) 25.98 (659.8) 0.31 (8) 1.2%
Width inches (mm)
10.83 (275) 11.22 (285) 0.39 (10) 3.6%
Circum. inches (mm)
80.62 (2047.69) 81.61 (2072.82) 0.99 (25.13) 1.2%
Sidewall Height inches (mm)
4.33 (110) 4.49 (114) 0.16 (4) 3.6%
Revolutions per mile (km)
785.93 (488.35) 776.4 (482.43) -9.53 (-5.92) -1.2%
Old Jan 10, 2017 | 05:42 PM
HioSSilver's Avatar
With 26" tires on the front and 27"s tires on the rear mine will throw the abs light.
You're probably ok at .3 difference.
Old Jan 10, 2017 | 10:46 PM
RevGTO's Avatar
Pontiacerator
Not a problem. I've run 245/50/16 front and 255/50/16 rear for years on end.
Old Jan 11, 2017 | 02:48 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I can say with 100% certainty, based on first hand experience, that this won't be an issue at all. I had a 275/40, 285/40 combo just like this for about two years on my '98.
Old Jan 11, 2017 | 06:13 AM
ragtopz28's Avatar
Thanks for the confirmation.
