What wheel size is good?
Offset: 35mm
Brand: Mach
18 x 8
275/40R17 was the largest factory size. With the right offset you can fit a 315 front and rear, so you can go much larger with no issue.
I would say you should sell those and find a similar style (c5 z06 wheel looks similar) that comes in a wider size. Going from 225 to 245 will look better but still look goofy especially on the rear.
https://ls1tech.com/forums/wheels-ti...l#post19239625
This tool is great to understand fitment
https://www.rimsntires.com/specspro.jsp
This is my thread, 18x9 +50 with 285/35-18s. Plenty wide and they fit no problem. Same offset and width as a stock wheel.
