Why is that? It does rub just a tiny bit if I turn real sharp but it hasn't been a real problem. Would I need longer studs on the front with 20mm spacers?
Will the car handle any better?
Same process you did with the rear. Spacers. Studs. Lugs.
Doubt you would notice the handling benefits unless you track it. Appearance wise would be a tremendous improvement
