Wheel backspace measuring tool
Old Jun 28, 2017 | 10:15 AM
dan96z71's Avatar
Default Wheel backspace measuring tool
I have seen some old posts about people talking about this. One even talked about renting one after he bought it.
I am in the stage of my chevelle build where I need to figure out wheels. I see a couple options out there for measuring tools, but they go from 90-500 dollars. I am thinking that means there is a huge difference in the way they work and how easy they are to use.
Is there any recommendations or anyone who would rent me theirs out there?
The one I was looking at is something like this and maybe this is my best bet:
http://www.1320wheels.com/index.php?...roducts_id=334
Old Jun 28, 2017 | 10:34 AM
squarles67's Avatar
I used the Percy's WheelRite. Way too much money for the plastic tool you get but it actually works quite well.
Old Jun 28, 2017 | 10:36 AM
dan96z71's Avatar
That is the one with the wire to make the tire height correct?
Old Jun 28, 2017 | 10:41 AM
squarles67's Avatar
Yes, worked well at cramming a 28 x 13.5 x 15 Hoosier QTP in my '55
Old Jul 2, 2017 | 04:34 PM
smitty2919's Avatar
Use a straight edge clamped to the wheel mount surface on the rotor and a tape measure?
Old Jul 3, 2017 | 08:13 AM
dan96z71's Avatar
What about the fronts?
Old Jul 3, 2017 | 05:58 PM
smitty2919's Avatar
Same thing. Jack up the car and place jackstand under LCA to load suspension. Then turn wheel and check for clearances. It should get you close.
