Pwo Z06
Old Jun 30, 2004 | 09:40 AM
PREDATOR-Z's Avatar
Default Pwo Z06
Good or bad?
If I choose them (Keeping in mind stock wheels are 50 mm offset all around)
Should I go with:
18 x 9.5 (50 mm offset) front
18 x 9.5 (56 mm offset) back
Or 18 x 9.5 (50 mm offset) All around
Tires are:
265/35/18 Yoko AVS Sport (Front)
285/35/18 Yoko AVS Sport (Back)
Thanks
Old Jun 30, 2004 | 11:29 AM
Xsta Z 28's Avatar
18" x 9.5" 50 mm all four corners. Look the best and you can still rotate your tires - if you use the same size tire on all four.
