Torque specs
Old Jul 3, 2004 | 01:41 AM
NUTBUTER's Avatar
Default Torque specs
any1 know where to find torque specs for wheels?? thanks
Old Jul 3, 2004 | 07:28 AM
99BlackWS6's Avatar
Here is that information right from GM service.
Install the tire and wheel (see attachment).
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install and hand tighten the wheel nuts and the security wheel lock nut, if equipped. Tighten
Tighten the nuts in increments of 27 N·m (20 lb ft) in sequence up to 140 N·m (100 lb ft).
Tighten the special security wheel lock nut, if equipped. Use a special security wheel lock key located in the front floor console.
Install the hub cap or the wheel trim cover, if equipped. Tighten
Tighten the wheel trim cover to 6 N·m (53 lb in).
Install the wheel nut cap, if equipped.
Lower the vehicle.
Old Jul 3, 2004 | 05:13 PM
RSpencer's Avatar
If you have aluminum wheels that 100lbs changes to 90lbs
Ralph
