Backspacing of a 15x3.5 Prostar
Old Jul 10, 2004 | 11:03 AM
Kurtomac's Avatar
Default Backspacing of a 15x3.5 Prostar
hey guys i need to know what backspacing for a 15x3.5 front runner should be is it 1.75" and should i run longer wheel studs all the way around, i will not be using spacers so i would not think it would be necessary, also wheres the best/cheapest place to order a set of Weld Prostars, ill be running 15x10 in the back, thanks, Kurt
Old Jul 10, 2004 | 02:18 PM
BTL FED's Avatar
1.75 is correct, you can run them with stock studs, but the arp londer studs are pretty cheap and a nice piece of mind, Jegs is where I bought my skinnies
Old Jul 11, 2004 | 07:42 PM
Kurtomac's Avatar
thanks whats the bolt pattern ill need?
Old Jul 11, 2004 | 08:12 PM
BTL FED's Avatar
5x4.75
