Spacer recommendation
Old Mar 6, 2019 | 02:01 PM
Miked5207's Avatar
Default Spacer recommendation
I am looking for spacer size recommendation for the setup that I am about to install below:
Koni STRs
UMI Lowering Springs - 1.25 front 1.5 rear
Front wheels - 18x8.5 46mm
Front Tires - 245/40/18
Rear Wheels - 19x10 70.5mm
Rear tires - 285/35/19
I understand the fronts are a little narrower then what some like to run, for the deal I got on the rims & tires I could not pass it up
Suggestions?
Old Mar 10, 2019 | 01:00 AM
TBSOELS1's Avatar
titanwheelaccesories is what I went with when I ran c5 wheels out back, 18x10.5 with 56 offset
