WS6 rim polishing?
Old Dec 17, 2019 | 12:31 PM
RJS1's Avatar
Default WS6 rim polishing?
What is everyone using on WS6 Speedline 17" factory wheels.
I believe they are coated from the factory but not as crisp looking as I would want them to be.
Thanks Ron
Old Dec 17, 2019 | 02:08 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Yes, these are factory clear coated so if you want to improve the quality of polishing to the actual metal you'd have to first remove the clear coat. Otherwise, all you can do is treat the clear finish with the same sort of compounds you'd use on other painted exterior finishes (clear safe).
