15" rims
Old Jul 16, 2004 | 09:05 AM
SDCE's Avatar
Default 15" rims
Will they fit on the back of your cars?
Old Jul 16, 2004 | 09:28 AM
smokinHawk's Avatar
huh?
um do you meen can you get 15" rims on if you grind the calipers.
moving to wheel section.
Old Jul 16, 2004 | 09:29 AM
smokinHawk's Avatar
wow somebody moved it while i posted
but yes you can if you grind the calipers.
Old Jul 16, 2004 | 10:55 AM
frcefed98's Avatar
Wendy, I run 15x10 Prostars on the back of my Formula. Backspacing is 7.5 inches. Like slokinhawk said above you have to grind the **** out of the calipers
Old Jul 16, 2004 | 06:18 PM
SJM Manufacturing Inc's Avatar
Some rims have more difficulty fitting then others.
We designed Bogart's to be a LS1/LT1 specific build and made to be a direct replacement for a STOCK setup.
You can view our gallary at
www.sjmmanufacturing.homestead.com
as well as www.mycamaroz28.homestead.com for more specific rims.
Hope this helps.
Steve
Pres.
Old Jul 16, 2004 | 09:00 PM
chris98pace's Avatar
Here is a pic of the bogarts mounted. give you kind of an idea. No grinding needed.
