Help with wheel specs...
Old Apr 21, 2020 | 08:37 PM
1998 TransAm's Avatar
Default Help with wheel specs...
Hey guys. Looking at wheels for my car. Here is where my issue comes in. I want to run 17 x 11 in the rear. Tire size would be a 315/35R17. Offset would normally be 45mm, but... I will be running 2015 Camaro rear Brembo calipers. Anyone running Brembos all around on their car? I know the ZR1 wheels will work but not with the brembos. If I use spacers to push them out, they will most likely rub the rear wheel wells. I am doing the Brembos up front as well. J55 front calipers from a 15 ATS. Tire size would be a 275. That's why if someone is familiar with this set up, any help would be appreciated.
