Wheel set up good or bad
Old May 3, 2020 | 02:05 AM
Perez0598's Avatar
Default Wheel set up good or bad
Quick question. I recently bought some 15x10 race stars and decided to order a 275/60/15 Nitto NT555R drag radial tire to mount on them. Should of probably ask before buying them but is a 28” tire a negative for my set up. Got a 99 trans am with a BTR stage 2 cam worked 243 heads 1 7/8” long tube headers 450 walbro pump melling oil pump and a 3800 circle d converter on 3.23 gears. At the time i wasnt thinking of how it can affect the cars performance only the stance
Old May 4, 2020 | 03:22 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
How sticky is your local track? Based on your likely power output and listed stall speed, the effective gear ratio reduction could help with traction during max effort launches if your track is known for poor prep or this setup is specifically for street action. My concern is more regarding tire width - why such a narrow tire for a 10" wide wheel? Or, rather, why select such a wide wheel if you only want to mount a 275mm tire? With a 60 series sidewall on a 15" diameter wheel, you could stuff a 275 on an 8" wide wheel (I've seen folks do this even on a 7" wide wheel, but I wouldn't personally recommend it). 10" width seems like overkill for a 275 tire even if it was a lower profile, but especially on a 60/15 setup.
Old May 4, 2020 | 07:16 AM
Perez0598's Avatar
I completely understand you 100% i didnt really wanna go with a 275 currently im on a 315/35/17 Nitto NT05R. I was looking for a 295-315 with a 50 or 60 side wall but couldnt find much. I did find some that were full on slicks for like 230 a piece or so but i didnt wanna spend another $500 for a set of tires, also dont need a full on slick for the power ill be putting down.. but if you can find another wider tire send me the link so i can take into consideration please and thanks!
