C6 rims
Old Mar 11, 2021 | 07:21 PM
chevy94c's Avatar
Default C6 rims
Looking into buying some used rims c6 18/19.. Will these fit on a forth gen without spacers ?
Old Mar 13, 2021 | 11:36 AM
BandDirector Blk98ZM6's Avatar
You'll need a 1.25" adapter/spacer on the rear 19x10's. The front 18x8.5's will fit, but the real problem is finding tire sizes to run the stock OEM C6 rims. To keep them from looking silly on an F-Body, the overall tire heights need to be within an inch of each other front to rear...that means the front sidewalls will be bigger on the front and to me that just looks odd. I tried this years ago and ended up going with the 19x10's all the way around with a 275/30/19 tire and 1.25" spacers on all 4 corners too. Worst ride, traction, and handling combo I've ever had on the car and I didn't keep them long. The C6 rim does look good on our cars, but my advice is to go aftermarket and get a set that's the same size all the way around that don't need spacers to work. I only paid $250 for my mint condition OEM C6 rim set, so I thought it was worth trying to make it work...but the good deal didn't really make up for all of the issues they created...
Old Mar 13, 2021 | 11:55 AM
chevy94c's Avatar
Thanks for giving me some info on this. I will definitely get some other rims.
Old Mar 13, 2021 | 12:21 PM
I did run these at one point too:
https://www.oewheelsllc.com/C6_8
They’re available in black too:
https://www.oewheelsllc.com/C6_7
275/35/18 tire on either will work. To be honest though, I always preferred the painted silver finish which I’ve never seen available in an aftermarket size to fit an F-body...
Old Mar 13, 2021 | 12:28 PM
...not sure why the links aren’t working...they’re both C6 18x9.5” wheels. One in chrome, one in black. Search their website and you’ll find them...
Old Mar 13, 2021 | 12:30 PM
chevy94c's Avatar
Yeah they link don't work but i will check them out. Thanks again for your help
