Will these fit?
Old May 26, 2021 | 01:18 PM
clambert's Avatar
Default Will these fit?
Will these wheels work on my 02 WS6 with stock ride height and what size tires should i go with
https://www.ebay.com/itm/27387026367...IAAOSw6IFeupH7
Old Jun 3, 2021 | 01:27 PM
hokeplaya05's Avatar
going to have to figure out what offset the 10.5 wheels are, i didn't see it in the link. the sticky has all the offset info you need as well as tire sizes for those wheels. you want to make sure the outer diameter of the front tire is the same as the rear so it doesn't throw your ABS off
https://ls1tech.com/forums/wheels-ti...must-read.html
