Nitto 555 fitment question...
Old Jul 21, 2004 | 12:40 PM
Gremlin5.3's Avatar
Default Nitto 555 fitment question...
I'm thinking of getting some 295/45/18 Nitto 555's (not 555R) for the rear. The only problem is my wheel is only 8.5" wide and the Nitto website recommends a 9.5" minimum wheel width. I currently have 285/50's and they fit fine. Do you think these tires would fit or would it cause to much of a bulge?
Thanks
Old Jul 21, 2004 | 12:57 PM
Orange Peel's Avatar
Sounds messed up to me, that tire height isn't right for a 18" wheel, should be a 35 series. And I wouldn't run a 295 on that 8.5" wheel, won't fit right. I would stick to a 275/35/18 on that rim. And you are running a 50 series on a 18" tire? Weird I run 285/35/18's on my 18x10.5 Z06 rim and it fits great, a 295 is doable on that width, but Nitto doesn't make a regular 555 in a 295
Old Jul 21, 2004 | 01:26 PM
Xsta Z 28's Avatar
First off, I'd say it is for a truck . . . sig?
As for the tire size, I'd say you are pushing it.
Old Jul 21, 2004 | 02:02 PM
****, stupid me didn't read that, damn trucks Forget what I said about tire height, but keep what I said about the width
Old Jul 21, 2004 | 02:13 PM
Gremlin5.3's Avatar
Yeah, it's for my truck. I guess I should have mentioned that since it's a taller tire than you guys run in your cars.
It's just weird that the Nitto site recommends a minimum 8" wheel for my 285/50 404's but a minimum 9.5" wheel for a 295/45 555. Seems like it should only be half an inch difference between the two.
Old Jul 21, 2004 | 02:27 PM
I would not go any larger than the 285 on that wheel bro, just to be safe, the tire will buldge too much and if something goes wrong with the tire, you are SOL if you try to get it warranteed.
