Custom wheels
Old Apr 8, 2022 | 02:15 AM
1994ChevyCamaro's Avatar
Default Custom wheels
Does anyone know of any companies that make reproduction c6 zr1 wheels that I can get in any offset and bolt pattern
Old Apr 10, 2022 | 04:18 PM
dlandsvZ28's Avatar
You might try posting on the Corvette forum. If the wheels are for your 1994 Camaro shouldn't be too hard to find a wheel with either 5 X 120 or 5 X 120.65. As for backspacing and offset that depends on the wheel size and width.
You might check out Billet Specialties, Weld Wheel, SJM mfg (Bogart wheels) etc. If you have deep pockets I am sure you can get whatever you want as long as what you want is safe to drive on.
For example, some C7 ZO6 and Grandsport wheels are cracking because of the design and the stiff sidewall of the run flats. The wheel on the base C7 Corvette doesn't have the issue. Not sure about the C6 ZR1 wheel. Might want to search the Corvette forums.
