stock wheel off sets
Old Mar 13, 2023 | 07:30 PM
wheeljunky's Avatar
Default stock wheel off sets
So i'm in a situation where i need new rotors. the previous company " Precision brake company" no longer exists.
I'm running 14 x1.25 rotors with no direct replacement available .So with that said I'm looking at Willwood big brake kit to get back to close to what i have. unfortunately they don't have the exact size hat that i have currently. So im concerned about the offset of my rim fitting.
Does anybody have the offset for a stock rim? my current rims look to have about 7" from back of the rim to the mounting surface.
this could help in making this right. this isnt what i intended on doing but it seems the only option to get her back on the road!!
TIA!!
Old Mar 13, 2023 | 11:21 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Offset for the factory wheels (at least the 17x9" ones) is +50mm, I don't remember if it's the same for the 16x8s. But it sounds like you're looking for the backspacing measurement (which can change depending on wheel width, even if offset does not).
Old Mar 14, 2023 | 07:35 AM
wheeljunky's Avatar
So if im understanding this correctly, its approximately 2.24 inches off-center. basically, towards the outer edge of the rim.. this would make sense..
thank you, this helps
