Mt ET street winter storage
Fill tank with 93 oct
Change oil
Pump tires to 38psi and park on furniture pads, I lay them out under the vehicle for insulation.
Plug in battery tender
Car cover
never had flat spots with my MT ET street radials. I live where it gets very cold.
Otherwise, I agree with the method of airing the tires up to max rated PSI (usually 44-52psi for the Z-rated tires I have owned) and parking on some sort of soft material (I use rubber backed carpeting, to block moisture under the whole car and give some cushion to the tires). I've had no issues with any permanent flat-spotting either, but I haven't personally done this with an ET Street.
