Lee
Old Feb 21, 2025 | 12:07 AM
LeePizana's Avatar
Default Lee
Hi my name is Lee. I'm new to this forum. I have a question about my 1999 camero. I would like to know if a 17x10 rim with a 7" back space will work on the front end? If so, what size of rubber is recommended?
Thanks for any and all advise!
Old Feb 21, 2025 | 08:34 AM
wssix99's Avatar
Save the manuals!
Welcome to the site. Did you use the search functionality to look to see if this has been discussed before? You can also use google to search this specific site and sometimes get better results. Odds are you will find what you are looking for and more!
Old Feb 21, 2025 | 09:10 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
My front setup is 17x9.5 7.3" BS/+52mm Offset with 275/40-17 tires for no interference & flush fit while I use 17x11 7.8" BS/+46mm Offset with 315/35-17 on the rear
I just ordered a set of Weld Forged S71's and during the process they stated 17x10" in their wheels would have suspension interference
For 18’s they recommended18x10 F +41 offset
18x11 R +43 offset
Most run a 275 F and a 305 rear tire set up.
