Need help with offset and bolt pattern
Old Aug 23, 2004 | 03:25 PM
Redlinez's Avatar
Default Need help with offset and bolt pattern
I'm looking at 3 different Weld wheels. I need to know the offset for 15 x 5 fronts and 15 x 8 and 15 x 10 rears. I saw in the sticky that the bolt pattern is 4.75 inches. Thanks for any help.
Old Aug 23, 2004 | 03:39 PM
AnthonyR's Avatar
don't know about the 15x5 but the 15x8 you need 5.5 backspace and for 15x10 you need 7.5 backspace.
Old Aug 23, 2004 | 04:53 PM
Redlinez's Avatar
I just called a lady at Weld and was told 4.5" backspace on 15 x 8, 4.75" bolt pattern. She didn't know the 15 x 10 numbers, which someone I know here said 7.5 as well. Thanks. Now for the decision of do I want to buy front and rear wheels and beat my inner fenderwells......
Old Aug 23, 2004 | 05:01 PM
Redlinez's Avatar
Better yet, is there a 16 x 8 wheel that is considerably lighter than the stock 5 star?? I may just go the 255-50-16 DR route.
Old Aug 23, 2004 | 07:44 PM
AnthonyR's Avatar
15x8 4.5 bs is gonna stick out of the fender a little too much I think...but if weld says it is ok then it is ok. Also if you go with welds you will have to grind the brake calipers to get them to fit
