What PSI with Drags? NEED TUBES!!!
Old Aug 29, 2004 | 09:35 AM
beardWS6's Avatar
Default What PSI with Drags? NEED TUBES!!!
Just curious, I`m buying a set of 28x10.5x15 M/T drags and was wondering what psi to run. Also, the tires recommend tubes, do I really need them. I don`t drive the tires on the street at all, just track! I never put them in my E/T streets and they worked fine. Thanks, you can see in sig my power and gear.
Old Aug 29, 2004 | 10:43 PM
Assassin's Avatar
I dont think the et streets required tubes cause they were intended for street use, the drags were made w/ the ideaw that the tires would get drilled to the rim, I run the tubes in my m/t drags and I would reccomend the same but you can test them out at over 100mph and let us all know how it goes, also want to run um at about 12psi depending on traction issues
