Broken wheel studs?
Old Oct 27, 2004 | 12:03 PM
taJon's Avatar
Default Broken wheel studs?
Has this happened to anyone else? How hard is it to change them? I kinda need to fix it right away so any help would be great.
Old Oct 27, 2004 | 02:14 PM
joshp14's Avatar
Easy to change....pull off the caliper, and the rotor. Smack the broken stud with a hammer until it falls out the back of the hub. Insert new stud from back side of hub, and install a stud installer. If you dont have a stud installer, use a lug nut. Tighten down with a impact or by hand until it stops.
