Question about different size tires...
The question, on an Fbody, how much tire height difference can you have, and still have trac control (never use it anyway) and ABS? I would like to lower the front a little with the stock 275/40/R17 on it, and get a tire that is taller in the rear (either more sidewall, or an 18" rim).
Some things I have read:
-You can't tune for the difference
-10% is the max difference
-5% is the max difference
If anyone knows, or has first hand knowledge, I would appreciate it. TIA
The size of the rim has nothing to do with the wheel rotation. Its the overall tire circumfrence of the tire.
Is that 10% the diameter or circumference differece? Thanks.
