BFH and rust
Old Nov 20, 2004 | 03:16 PM
tuffluck's Avatar
Default BFH and rust
one of my tires was rubbing in one spot, so i took the hammer to it. the black stuff that the wheel well is coated with flaked off on that spot and left bare paint. is it going to rust and start rusting all underneath there? is all the black stuff going to start flaking off now also?
Old Nov 20, 2004 | 03:22 PM
Angus's Avatar
You can go get that bedliner stuff and put a coat of it on there. that might solve it.
Old Nov 20, 2004 | 03:24 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Yah we all need to do that kind of stuff.
Old Nov 20, 2004 | 03:27 PM
tuffluck's Avatar
so is it necessary? i mean, is it actually going to rust or start flaking off? or is something totally not even worth considering?
where do you get that bedliner stuff?
Old Nov 21, 2004 | 12:19 AM
tuffluck's Avatar
being serious? ...anyone know?
Old Nov 21, 2004 | 12:23 AM
5POINT7's Avatar
I BFH'd my wheel wells to fit my 17x11's. All that black undercoating came flaking off. I bought a can of rubberized undercoating from WalMart and re-sprayed it. I've had no problems since. I would think it is necessary to re-spray after BFH...it just makes sense to.
Old Nov 21, 2004 | 02:38 AM
2MuchRiceMakesMeSick's Avatar
There is alot of water in that area in the rain. I would think that would be necissary I resprayed mine as well.
Old Nov 21, 2004 | 01:01 PM
tuffluck's Avatar
where in walmart can i find the rubberized undercoating stuff? thanks.
Old Nov 21, 2004 | 02:39 PM
tuffluck's Avatar
i bought some of that stuff. there was already a very little bit of surface rust forming there (it's been raining here), so i just sprayed over it. i'm assuming this stuff will keep that metal from rusting further, even though surface rust is no big deal anyway.
i'm also thinking about covering the whole inside of the wheel well with this stuff for two reasons: it's a lot blacker than the other stuff the factory uses, and it is supposedly a sound deadener.
