3.5 or 4 in prostars???
Old Jan 10, 2005 | 10:15 PM
chrismcdaniel's Avatar
Default 3.5 or 4 in prostars???
just ondering if there was less grinding required with the 3.5 or any other benefit of it over the 4 in.
Old Jan 11, 2005 | 12:05 AM
come on, someone has to have some input on this subject..
Old Jan 11, 2005 | 11:42 AM
ONGRNGO's Avatar
I just got my 15X3.5 Prostars because they require less grinding, and you can run w/o spacers if you grind enough. Me I would rather run w/o spacers.
Dan
Old Jan 11, 2005 | 12:50 PM
STL2SLO's Avatar
The width of the rim doesn't matter I don't think. I am pretty sure grinding is req'd because of the way the wheel is made on the inside of the wheel...
Old Jan 14, 2005 | 10:24 AM
Derek98z's Avatar
15x3.5 with grinding and no spacer!
Old Jan 14, 2005 | 11:10 AM
Bad Blu Formula's Avatar
15x3.5s have been a little more popular. Also, less weight man.
