315's in the rear. need pics I'm looking to get a set of CCW 505A's. They would be 19x11 in back. I'm looking at tires, welll the few that fit, and need suggestions. I need pics of 315's in back to see if they stick outside of the fender. I want the widest tires possible with out going outside the fender? I'm not looking to get the same tire for front and rear if that helps.Also, what modifications/adjustments are needed to makes this set up work? ex: pounding out the inner wheel well.... |
on my site there is a pic i photoshopped of the ccw wheels, i assume it would take alot of custom work to get the 19" wheel to fit in there, and you probably will have to run something low profile with such a big wheel. Usually a 315 wont stick out of the fender at the top, but towards the bottom the tire comes out a little as the fender swoop's back, i would probably say it all depends on the offest of the wheels. I would contact ccw and see what they can tell you. Here's a few pics from another thread with someone using nitto 315's http://img8.exs.cx/img8/5374/k0cim001311.jpg http://img50.exs.cx/img50/91/e6wfikse.jpg |
| All times are GMT -5. The time now is 02:53 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
