315's in the rear. need pics
Old Jan 23, 2005 | 03:29 PM
2002_LPE_SS's Avatar
Default 315's in the rear. need pics
I'm looking to get a set of CCW 505A's. They would be 19x11 in back. I'm looking at tires, welll the few that fit, and need suggestions. I need pics of 315's in back to see if they stick outside of the fender. I want the widest tires possible with out going outside the fender? I'm not looking to get the same tire for front and rear if that helps.Also, what modifications/adjustments are needed to makes this set up work?
ex: pounding out the inner wheel well....
Old Jan 24, 2005 | 11:36 AM
Quick 99's Avatar
on my site there is a pic i photoshopped of the ccw wheels, i assume it would take alot of custom work to get the 19" wheel to fit in there, and you probably will have to run something low profile with such a big wheel. Usually a 315 wont stick out of the fender at the top, but towards the bottom the tire comes out a little as the fender swoop's back, i would probably say it all depends on the offest of the wheels. I would contact ccw and see what they can tell you.
Here's a few pics from another thread with someone using nitto 315's
