Need help chosing ARP wheel stud ...
Old Feb 19, 2005 | 03:52 PM
Fierce-LS1's Avatar
Default Need help chosing ARP wheel stud ...
If I want to run larger spacers, do I need the press in or the screw in type for the front and back ?
Also, what thread size do I need ?
thanks ... appreciate any input
Old Feb 19, 2005 | 07:34 PM
frcefed98's Avatar
113-100-7708 ARP Wheel Studs,
12mm X 1.5, 2.5" length
They are press in and can be ordered from most our sponsor or jegs or summit racing.
J
Old Feb 19, 2005 | 09:11 PM
Fierce-LS1's Avatar
J
thanks frcefed98 ... you've always been a great HELP !
Old Apr 20, 2005 | 07:52 AM
ramairbrc's Avatar
I'm wondering why the most popular wheel stude replacement requires using different lug nuts, when there are 12mm x 1.25" performance wheel studs available.
Thanks.
Old Apr 20, 2005 | 08:59 AM
LS69TA's Avatar
Same here. I'd like to be able to still use my Gorilla locks when I switch back to my 17's.
Old Apr 20, 2005 | 03:42 PM
Xsta Z 28's Avatar
You can still use your OEM lug nuts . . . Same thread pattern . . . The only issue comes into play is that the stud may be too long for some of the closed end lugs.
