tire wear problem???
Old Feb 21, 2005 | 10:12 PM
SSideExhLS1's Avatar
Default tire wear problem???
the inside of my rear driver's side tire wears in about 6k miles(drags). the front tires are fine and my rear passenger too. only problem is left rear and in the inside of the tire??what could be causing this premature wear????
Old Feb 22, 2005 | 08:08 AM
Xsta Z 28's Avatar
Bent wheel, bent axle, rear axle not in line with the front "axle" . . .
Old Feb 22, 2005 | 08:34 AM
abadss's Avatar
something sounds like it is wrong with the alignment of the axle somehow. check with a alignment shop they may know
Old Feb 22, 2005 | 09:59 AM
sixvi6-camaro's Avatar
well if you have adjustable LCA's in there those could be off. If its all stock in the rear I dunno what would cause it because there is nothing to align in the rear.. was the car ever wrecked? Hit a curb with the rear or even a large pothole or anyhitng like that? a bent axle, rim, or even a slight tweak in the housing or a tweaked LCA or completely rotted out or bad bushing in an LCA could cause the rearend to be misaligned.
Old Feb 22, 2005 | 10:53 PM
Goodrich's Avatar
Bent axle tube maybe? If you have the stock 10bolt have it checked out.
