Another 315 / lowered rubbing question (sorry)...
1. Some cars just seem to have more rubbing issues.
2. Do you have an adjustable PHR to center the rear? That will help...
3. Do you have the 'right' offset for the rims? Too small and you could rub the outside fender...too big, and you could rub the inside fender.
4. You will certainly have problems with the bump stop if you try to jack up your car without putting the jack under the differential. At full extension, the rim/tire will catch on the bump stop.
All that said though, it just takes a little hammer work on the inside fender, and a little 'rolling' on the outside fender...
